Skip to main content
Dependabot options reference
Detailed information for all the options you can use to customize how Dependabot maintains your repositories.
Who can use this feature?
Users with write access
About the dependabot.yml file
The dependabot.yml file defines how Dependabot maintains dependencies using version updates. In addition, all options marked with a icon also change how Dependabot creates pull requests for security updates, except where target-branch is used.
The Dependabot configuration file, dependabot.yml, uses YAML syntax. If you're new to YAML and want to learn more, see Learn YAML in five minutes.
You must store this file in the .github directory of your repository in the default branch. When you add or update the dependabot.yml file, this triggers an immediate check for version updates. For more information and an example, see Configuring Dependabot version updates.
Note
Dependabot alerts are configured in the repository or organization "Settings" tab and not in the dependabot.yml file, see Configuring Dependabot alerts.
Required keys
KeyLocationPurpose
versionTop levelDependabot configuration syntax to use. Always: 2.
updatesTop levelSection where you define each package-ecosystem to update.
package-ecosystemUnder updatesDefine a package manager to update.
directories or directoryUnder each package-ecosystem entryDefine the location of the manifest or other definition files to update.
schedule.intervalUnder each package-ecosystem entryDefine whether to look for version updates: daily, weekly, or monthly.
Optionally, you can also include a top-level registries key to define access details for private registries, see Top-level registries key.
YAML
# Basic `dependabot.yml` file with
# minimum configuration for two package managers
version: 2
updates:
  # Enable version updates for npm
  - package-ecosystem: "npm"
    # Look for `package.json` and `lock` files in the `root` directory
    directory: "/"
    # Check the npm registry for updates every day (weekdays)
    schedule:
      interval: "daily"
  # Enable version updates for Docker
  - package-ecosystem: "docker"
    # Look for a `Dockerfile` in the `root` directory
    directory: "/"
    # Check for updates once a week
    schedule:
      interval: "weekly"
For a real-world example of a dependabot.yml file, see Dependabot's own configuration file.
allow
Use to define exactly which dependencies to maintain for a package ecosystem. Often used with the ignore option. For examples, see Controlling which dependencies are updated by Dependabot.
Dependabot default behavior:
  • All dependencies explicitly defined in a manifest are kept up to date by version updates.
  • All dependencies defined in lock files with vulnerable dependencies are updated by security updates.
When allow is specified Dependabot uses the following process:
  1. Check for all explicitly allowed dependencies.
  2. Then filter out any ignored dependencies or versions.
    If a dependency is matched by an allow and an ignore statement, then it is ignored.
ParametersPurpose
dependency-nameAllow updates for dependencies with matching names, optionally using * to match zero or more characters.
dependency-typeAllow updates for dependencies of specific types.
dependency-name (allow)
For most package managers, you should define a value that will match the dependency name specified in the lock or manifest file. A few systems have more complex requirements.
Package managerFormat requiredExample
Gradle and MavengroupId:artifactIdorg.kohsuke:github-api
Docker for image tagsThe full name of the repositoryFor an image tag of <account ID>.dkr.ecr.us-west-2.amazonaws.com/base/foo/bar/ruby:3.1.0-focal-jemalloc, use base/foo/bar/ruby.
dependency-type (allow)
Dependency typesSupported by package managersAllow updates
directAllAll explicitly defined dependencies.
indirectbundler, pip, composer, cargo, gomodDependencies of direct dependencies (also known as sub-dependencies, or transient dependencies).
allAllAll explicitly defined dependencies. For bundler, pip, composer, cargo, gomod, also the dependencies of direct dependencies.
productionbundler, composer, mix, maven, npm, pip (not all managers)Only to dependencies defined by the package manager as production dependencies.
developmentbundler, composer, mix, maven, npm, pip (not all managers)Only to dependencies defined by the package manager as development dependencies.
assignees
Specify individual assignees for all pull requests raised for a package ecosystem. For examples, see Customizing Dependabot pull requests to fit your processes.
  • Pull requests are created without any assignees.
When assignees is defined:
  • All pull requests for version updates are created with the chosen assignees.
  • All pull requests for security updates are created with the chosen assignees, unless target-branch defines updates to a non-default branch.
Assignees must have write access to the repository. For organization-owned repositories, organization members with read access are also valid assignees.
commit-message
Define the format for commit messages. Since the titles of pull requests are written based on commit messages, this setting also impacts the titles of pull requests. For examples, see Customizing Dependabot pull requests to fit your processes.
  • Commit messages follow similar patterns to those detected in the repository.
When commit-message is defined:
  • All commit messages follow the defined pattern.
  • All commit messages follow the defined pattern, unless target-branch defines updates to a non-default branch.
ParametersPurpose
prefixDefines a prefix for all commit messages and pull request titles.
prefix-developmentOn supported systems, defines a different prefix to use for commits that update dependencies in the Development dependency group.
includeFollow the commit message prefix with additional information.
Tip
When pull requests are raised for grouped updates, the branch name and pull request title are defined by the group IDENTIFIER, see groups.
prefix
  • Used for all commit messages unless prefix-development is also defined.
  • Value can be up to 50 characters.
  • Dependabot inserts a colon after the prefix before adding the main commit message when the value ends with a letter, number, closing parenthesis, or closing bracket.
  • End the value with a whitespace character to stop a colon being added.
prefix-development
Supported by: bundler, composer, mix, maven, npm, and pip.
  • Used only for commit messages that update dependencies in the Development dependency group.
  • Otherwise, the parameter behaves exactly as the prefix parameter.
include
  • Supports only the value scope
  • When defined any prefix is followed by the type of dependencies updated in the commit: deps or deps-dev.
Required option. Use to define the location of the package manifests for each package manager (for example, the package.json or Gemfile). Without this information Dependabot cannot create pull requests for version updates. For examples, see Defining multiple locations for manifest files.
  • Use directory to define a single directory of manifests.
  • Use directories to define a list of multiple directories of manifests.
  • Define directories relative to the root of the repository for most package managers.
  • For GitHub Actions, use the value /. Dependabot will search the /.github/workflows directory, as well as the action.yml/action.yaml file from the root directory.
If you need to use more than one block in the configuration file to define updates for a single target branch of an ecosystem, you must ensure that all values are unique and there is no overlap in directories defined.
Note
The directories key supports globbing and the wildcard character *. These features are not supported by the directory key.
enable-beta-ecosystems
Not currently in use.
groups
Define rules to create one or more sets of dependencies managed by a package manager, to group updates into fewer, targeted pull requests. For examples, see Optimizing the creation of pull requests for Dependabot version updates.
  • Open a single pull request for each dependency that needs to be updated to a newer version for version updates and for security updates.
When groups is used to define rules:
  • All updates for dependencies that match a rule are combined in a single pull request.
  • If a dependency matches more than one rule, it's included in the first group that it matches.
  • Any outdated dependencies that do not match a rule are updated in individual pull requests.
ParametersPurpose
IDENTIFIERDefine an identifier for the group to use in branch names and pull request titles. This must start and end with a letter, and can contain letters, pipes |, underscores _, or hyphens -.
applies-toSpecify which type of update the group applies to. When undefined, defaults to version updates. Supported values: version-updates or security-updates.
dependency-typeLimit the group to a type. Supported values: development or production.
patternsDefine one or more patterns to include dependencies with matching names.
exclude-patternsDefine one or more patterns to exclude dependencies from the group.
update-typesLimit the group to one or more semantic versioning levels. Supported values: minor, patch, and major.
dependency-type (groups)
By default, a group will include all types of dependencies.
  • Use development to include only dependencies in the "Development dependency group".
  • Use production to include only dependencies in the "Production dependency group".
patterns and exclude-patterns (groups)
Both options support using * as a wild card to define matches with dependency names. If a dependency matches both a pattern and an exclude-pattern, then it is excluded from the group.
update-types (groups)
By default, a group will include updates for all semantic versions (SemVer). SemVer is an accepted standard for defining versions of software packages, in the form x.y.z. Dependabot assumes that versions in this form are always major.minor.patch.
  • Use patch to include patch releases.
  • Use minor to include minor releases.
  • Use major to include major releases.
ignore
Use with the allow option to define exactly which dependencies to maintain for a package ecosystem. Dependabot checks for all allowed dependencies and then filters out any ignored dependencies or versions. So a dependency that is matched by both an allow and an ignore will be ignored. For examples, see Controlling which dependencies are updated by Dependabot.
When ignore is used Dependabot uses the following process:
ParametersPurpose
dependency-nameIgnore updates for dependencies with matching names, optionally using * to match zero or more characters.
versionsIgnore specific versions or ranges of versions.
update-typesIgnore updates to one or more semantic versioning levels. Supported values: version-update:semver-minor, version-update:semver-patch, and version-update:semver-major.
dependency-name (ignore)
versions (ignore)
Use to ignore specific versions or ranges of versions. If you want to define a range, use the standard pattern for the package manager. For example:
  • npm: use ^1.0.0
  • Bundler: use ~> 2.0
  • Docker: use Bundler version syntax
  • NuGet: use 7.*
  • Maven: use [1.4,)
update-types (ignore)
Specify which semantic versions (SemVer) to ignore. SemVer is an accepted standard for defining versions of software packages, in the form x.y.z. Dependabot assumes that versions in this form are always major.minor.patch.
insecure-external-code-execution
Supported by: bundler, mix, and pip.
Allow Dependabot to execute external code in the manifest during updates. For examples, see Allowing external code execution.
  • When you give Dependabot access to one or more registries, external code execution is automatically disabled to protect your code from compromised packages.
  • Version updates may fail without the ability to execute code.
When you allow insecure-external-code-execution:
  • Dependabot will execute code in the manifest as part of the version update process.
  • The code has access to only the package managers in the registries associated with that updatessetting. There is no access allowed to any of the registries defined in the top level registries configuration.
  • This should enable the update to succeed but also could allow a compromised package to steal credentials or gain access to configured registries.
Supported value: allow.
labels
Specify your own labels for all pull requests raised for a package manager. For examples, see Customizing Dependabot pull requests to fit your processes.
  • All pull requests have a dependencies label.
  • If you define more than one package manager, an additional label for the ecosystem or language is added to each pull request. For example: java for Gradle updates and submodules for git submodule updates.
  • Dependabot creates these default labels automatically, as necessary in your repository.
When labels is defined:
  • The labels specified are used instead of the default labels.
  • If any of these labels is not defined in the repository, it is ignored.
  • You can disable all labels, including the default labels, using labels: [ ].
Setting this option will also affect pull requests for security updates to the manifest files of this package manager, unless you use target-branch to check for version updates on a non-default branch.
milestone
Associate all pull requests raised for a package manager with a milestone. For examples, see Customizing Dependabot pull requests to fit your processes.
  • No milestones are used.
When milestone is defined:
  • All pull requests for the package manager are added to the milestone.
Supported value: the numeric identifier of a milestone.
Tip
If you view a milestone, the final part of the page URL, after milestone, is the identifier. For example: https://github.com/<org>/<repo>/milestone/3, see Viewing your milestone's progress.
open-pull-requests-limit
Change the limit on the maximum number of pull requests for version updates open at any time.
  • If five pull requests with version updates are open, no further pull requests are raised until some of those open requests are merged or closed.
  • Security updates have a separate, internal limit of ten open pull requests which cannot be changed.
When open-pull-requests-limit is defined:
  • Dependabot opens pull requests up to the defined integer value.
  • You can temporarily disable version updates for a package manager by setting this option to zero, see Disabling Dependabot version updates.
package-ecosystem
Required option. Define one package-ecosystem element for each package manager that you want Dependabot to monitor for new versions. The repository must also contain a dependency manifest or lock file for each package manager, see Example dependabot.yml file.
Package managerYAML valueSupported versions
Bunbun>=v1.1.39
Bundlerbundlerv2
Cargocargov1
Composercomposerv2
Dev containersdevcontainersNot applicable
Dockerdockerv1
Docker Composedocker-composev2, v3
.NET SDKdotnet-sdk>=.NET Core 3.1
Helm Chartshelmv3
Hexmixv1
elm-packageelmv0.19
git submodulegitsubmoduleNot applicable
GitHub Actionsgithub-actionsNot applicable
Go modulesgomodv1
GradlegradleNot applicable
MavenmavenNot applicable
npmnpmv7, v8, v9
NuGetnuget<=6.12.0
pippipv21.1.2
pip-compilepip6.1.0
pipenvpip<= 2021-05-29
pnpmnpmv7, v8
v9 (version updates only)
poetrypipv2
pubpubv2
Swiftswiftv5
Terraformterraform>= 0.13, <= 1.10.x
uvuvv0
yarnnpmv1, v2, v3
pull-request-branch-name.separator
Specify a separator to use when generating branch names. For examples, see Customizing Dependabot pull requests to fit your processes.
  • Generate branch names of the form: dependabot/PACKAGE_MANAGER/DEPENDENCY
When pull-request-branch-name.separator is defined:
  • Use the specified character in place of /.
Supported values: "-", _, /
Tip
The hyphen symbol must be escaped so it is not interpreted as starting an empty YAML list.
rebase-strategy
Disable automatic rebasing of pull requests raised by Dependabot.
Dependabot default behavior is to rebase open pull requests when Dependabot detects any changes to a version or security update pull request. Dependabot checks for changes when:
  • Your schedule runs to check for version updates.
  • You reopen a closed Dependabot pull request.
  • You change the value of target-branch in the Dependabot configuration file, see target-branch.
  • A Dependabot pull request is in conflict after a recent push to the target branch.
When rebase-strategy is set to disabled, Dependabot stops rebasing pull requests.
Note
Pull requests that were open before you disable rebasing will continue to be rebased until 30 days after they were opened. This affects all pull requests that have conflicts with the target branch and all pull requests for version updates.
registries
Configure access to private package registries to allow Dependabot to update a wider range of dependencies, see Configuring access to private registries for Dependabot and Guidance for the configuration of private registries for Dependabot.
There are 2 locations in the dependabot.yml file where you can use the registries key:
  1. At the top level, where you define the private registries you want to use and their access information, see Configuring access to private registries for Dependabot.
  2. Within the updates blocks, where you can specify which private registries each package manager should use.
Dependabot default behavior is to raise pull requests only to update dependencies stored in publicly accessible registries.
When the Dependabot configuration file has a top-level registries section, defining access to one or more private registries, you can configure each package-ecosystem to use one or more of these private registries.
When registries is defined for a package manager:
  • Each private registry specified for a package manager is checked for version and security updates.
  • Dependabot uses the access details defined in the top-level registries section.
Supported values: REGISTRY_NAME or "*"
reviewers
Specify individual reviewers, or teams of reviewers, for all pull requests raised for a package manager. For examples, see Customizing Dependabot pull requests to fit your processes.
  • Pull requests are created without any reviewers assigned.
When reviewers is defined:
  • All pull requests for version updates are created with the chosen reviewers.
  • All pull requests for security updates are created with the chosen reviewers, unless target-branch defines updates to a non-default branch.
Reviewers must have at least read access to the repository.
schedule
Required option. Define how often to check for new versions for each package manager you configure using the interval parameter. Optionally, for daily and weekly intervals, you can customize when Dependabot checks for updates. For examples, see Optimizing the creation of pull requests for Dependabot version updates.
ParametersPurpose
intervalRequired. Defines the frequency for Dependabot.
daySpecify the day to run for a weekly interval.
timeSpecify the time to run.
cronjobDefines the cron expression if the interval type is cron.
timezoneSpecify the timezone of the time value.
interval
Supported values: daily, weekly, monthly, quarterly, semiannually, yearly, or cron
Each package manager must define a schedule interval.
  • Use daily to run on every weekday, Monday to Friday.
  • Use weekly to run once a week, by default on Monday.
  • Use monthly to run on the first day of each month.
  • Use quarterly to run on the first day of each quarter (January, April, July, and October).
  • Use semiannually to run every six months, on the first day of January and July.
  • Use yearly to run on the first day of January.
  • Use cron for cron expression based scheduling option. See cronjob.
By default, Dependabot randomly assigns a time to apply all the updates in the configuration file. You can use the time and timezone parameters to set a specific runtime for all intervals. If you use a cron interval, you can define the update time with a cronjob expression.
day
Supported values: monday, tuesday, wednesday, thursday, friday, saturday, or sunday
Optionally, run weekly updates for a package manager on a specific day of the week.
time
Format: hh:mm
Optionally, run all updates for a package manager at a specific time of day. By default, times are interpreted as UTC.
cronjob
Supported values: Valid cron expression in cron format or natural expression.
Examples : 0 9 * * *, every day at 5pm
cron format is defined as the following:
  • * The minute field.
  • * The hour field (in 24-hour time).
  • * The day of the month (matches any day of the month).
  • * The month (matches any month).
  • * The day of the week (matches any day of the week).
0 9 * * * is equivalent to "every day at 9am". every day at 5pm is equivalent to 0 17 * * *.
Note
A cronjob type schedule is required to use a cron interval.
YAML
# Basic `dependabot.yml` file for cronjob
version: 2
updates:
    directory: "/"
    # Check the npm registry for updates based on `cronjob` value
    schedule:
      interval: "cron"
      cronjob: "0 9 * * *"
timezone
Specify a time zone for the time value.
The time zone identifier must match a timezone in the database maintained by iana, see List of tz database time zones.
target-branch
Define a specific branch to check for version updates and to target pull requests for version updates against. For examples, see Customizing Dependabot pull requests to fit your processes.
When target-branch is defined:
  • Only manifest files on the target branch are checked for version updates.
  • All pull requests for version updates are opened targetting the specified branch.
  • Options defined for this package-ecosystem no longer apply to security updates because security updates always use the default branch for the repository.
vendor
Supported by: bundler and gomod only.
Tell Dependabot to maintain your vendored dependencies as well as the dependencies defined by manifest files. A dependency is described as "vendored" or "cached" when you store the code within your repository, see bundle cache documentation and go mod vendor documentation.
  • Maintain only dependencies recorded in the manifest and lock files identified for Bundler.
  • Raise security and version update pull requests that update the version numbers recorded in the manifest and lock files.
  • For Go modules, any vendored dependencies are automatically identified and maintained as if vendor was enabled.
When vendor is enabled:
  • Dependabot also maintains dependencies for Bundler that are stored in the _vendor/cache_ directory in the repository.
  • Pull requests will sometimes contain updates to a dependency that is stored in the repository.
Supported values: true or false
versioning-strategy
Supported by: bundler, cargo, composer, mix, npm, pip, pub
Define how Dependabot should edit manifest files. For examples, see Controlling which dependencies are updated by Dependabot.
  • Try to differentiate between app and library dependencies.
  • For apps, always increase the minimum version requirement to match the new version. The increase strategy.
  • For libraries, widen the allowed version requirements to include both the new and old versions, when possible. The widen strategy.
When versioning-strategy is defined, Dependabot uses the strategy specified.
ValueBehavior
autoDefault behavior.
increaseAlways increase the minimum version requirement to match the new version. If a range already exists, typically this only increases the lower bound.
increase-if-necessaryLeave the constraint if the original constraint allows the new version, otherwise, bump the constraint.
lockfile-onlyOnly create pull requests to update lockfiles. Ignore any new versions that would require package manifest changes.
widenWiden the allowed version requirements to include both the new and old versions, when possible. Typically, this only increases the maximum allowed version requirement.
For example, if the current version is 1.0.0 and the current constraint is ^1.0.0 the different strategies would raise the following updates:
New version 1.2.0
  • increase: new constraint ^1.2.0
  • increase-if-necessary: new constraint ^1.0.0
  • widen: new constraint ^1.0.0
New version 2.0.0
  • increase: new constraint ^2.0.0
  • increase-if-necessary: new constraint ^2.0.0
  • widen: new constraint >=1.0.0 <3.0.0
Note
If the package manager you use does not yet support configuring the versioning-strategy parameter, or does not support a value you need. The strategy code is open source, so if you'd like a particular ecosystem to support a new strategy, you are always welcome to submit a pull request in https://github.com/dependabot/dependabot-core/.
Versioning tags
  • Represent stages in the software release lifecycle, such as alpha, beta, and stable versions.
  • Allow publishers to distribute their packages more effectively.
  • Indicate the stability of a version and communicate what users should expect in terms of features and stability.
Dependabot recognizes a variety of versioning tags for pre-releases, stable versions, and custom tags across different ecosystems.
The dependabot.yml file doesn't control the versioning tags that you can use, but you can define in configuration options such as ignore the supported versioning tags you want to ignore updates for.
Supported versioning tags
Package ManagerYAML valueSupported TagsExamples
Mavenmavenalpha, a, beta, b, milestone, m, rc, cr, sp, ga, final, release, snapshotspring-security-web@5.6.0-SNAPSHOT, spring-core@5.2.0.RELEASE
npmnpmalpha, beta, canary, dev, experimental, latest, legacy, next, nightly, rc, release, stablelodash@beta, react@latest, express@next
pnpmnpmalpha, beta, canary, dev, experimental, latest, legacy, next, nightly, rc, release, stablelodash@1.2.0-alpha, react@alpha, vue@next
yarnnpmalpha, beta, canary, dev, experimental, latest, legacy, next, nightly, rc, release, stablelodash@1.2.0-alpha, axios@latest, moment@nightly
Versioning tag glossary
  • alpha: Early version, may be unstable and have incomplete features.
  • beta: More stable than alpha but may still have bugs.
  • canary: Regularly updated pre-release version for testing.
  • dev: Represents development versions.
  • experimental: Versions with experimental features.
  • latest: The latest stable release.
  • legacy: Older or deprecated versions.
  • next: Upcoming release version.
  • nightly: Versions built nightly; often includes the latest changes.
  • rc: Release candidate, close to stable release.
  • release: The official release version.
  • stable: The most reliable, production-ready version.
Specify authentication details that Dependabot can use to access private package registries, including registries hosted by GitLab or Bitbucket.
The value of the registries key is an associative array, each element of which consists of a key that identifies a particular registry and a value which is an associative array that specifies the settings required to access that registry. The following dependabot.yml file configures a registry identified as dockerhub in the registries section of the file and then references this in the updates section of the file.
YAML
# Minimal settings to update dependencies stored in one private registry
version: 2
registries:
  dockerhub: # Define access for a private registry
    type: docker-registry
    url: registry.hub.docker.com
    username: octocat
    password: ${{secrets.DOCKERHUB_PASSWORD}}
updates:
    directory: "/docker-registry/dockerhub"
    registries:
      - dockerhub # Allow version updates for dependencies in this registry
    schedule:
      interval: "monthly"
You use the following options to specify access settings. Registry settings must contain a type and a url, and typically either a username and password combination or a token.
ParametersPurpose
REGISTRY_NAMERequired: Defines an identifier for the registry.
typeRequired: Identifies the type of registry.
Authentication detailsRequired: The parameters supported for supplying authentication details vary for registries of different types.
urlRequired: The URL to use to access the dependencies in this registry. The protocol is optional. If not specified, https:// is assumed. Dependabot adds or ignores trailing slashes as required.
replaces-baseIf the boolean value is true, Dependabot resolves dependencies using the specified url rather than the base URL of that ecosystem.
Note
nuget-feed doesn't support the replaces-base parameter.
For in-depth information about available options, as well as recommendations and advice when configuring private registries, see Guidance for the configuration of private registries for Dependabot.
type and authentication details
The parameters used to provide authentication details for access to a private registry vary according to the registry type.
Registry typeRequired authentication parameters
cargo-registrytoken
composer-repositoryusername and password
docker-registryusername and password
gitusername and password
hex-organizationorganization and key
hex-repositoryrepo and auth-key optionally with the corresponding public-key-fingerprint
maven-repositoryusername and password
npm-registryusername and password
or token
nuget-feedusername and password
or token
pub-registrytoken
python-indexusername and password
or token
rubygems-serverusername and password
or token
terraform-registrytoken
All sensitive data used for authentication should be stored securely and referenced from that secure location, see Configuring access to private registries for Dependabot.
Tip
If the account is a GitHub account, you can use a GitHub personal access token in place of the password.
url and replaces-base
The url parameter defines where to access a registry. When the optional replaces-base parameter is enabled (true), Dependabot resolves dependencies using the value of url rather than the base URL of that specific ecosystem.
Note
